PiledHigher wrote:squeazasis wrote:PiledHigher wrote:squeazasis wrote:Just out of interest, what is different about the frames of women-specific bikes (apart from being one size smaller)? When I was looking at bikes in shops, at one point one staff member said to me "women have longer legs and shorter trunks...." er, hello, isn't it the opposite??
On average women have proportionally longer legs and shorter trunks, that is different from teh fact that on average they are shorter as well.
I knew that either way it was different from the fact that on average women are shorter.... but I really thought it was the opposite!
Best not to let facts get in the way of a good argument...
sachamc wrote:I've found that "women's specific" sometimes means a compact style frame, or it can mean the standard geometry frame with girly bits on it. I think Giant does the latter, or at least they did a few years ago when I was looking for a bike. I have a short torso and long thigh bones and no amount of adjustment was going to get me to fit on a Giant road bike, "women's specific" or not. Then I tried a Specialized Ruby women's specific bike and it fit within about 10min of adjustment.
When I went looking for my next bike I knew the frame measurements and geometry that fit me best and I looked at a whole heap of brands and compared the frames, some womens's specific and some "mens" (unisex). None of the mens compact frames that I looked at came in a size small enough to fit although the angles of the frame were pretty good. So I ended up buying another WSD bike. An Orbea. It only came in 2 sizes and luckily I fit the smallest size. Not sure what you would do if you were shorter. I'm 5'4" so not exactly short. Knowing a bit more about bikes by this time I had the bike put together to my specifications, choosing shorter cranks, and a saddle I liked (I need a narrow saddle, not a big wide one they usually put on women's bikes) In terms of the handlebars, when they measured me up the guy said he'd never seen anyone with narrower shoulders. So I had to get the smallest bars you can get, which really are still a bit wide for me, but not much I can do if there are no narrower ones (plus it's annoying that it reduces the amount of space for lights and such things)
squeazasis wrote:PiledHigher wrote:squeazasis wrote:PiledHigher wrote:squeazasis wrote:Just out of interest, what is different about the frames of women-specific bikes (apart from being one size smaller)? When I was looking at bikes in shops, at one point one staff member said to me "women have longer legs and shorter trunks...." er, hello, isn't it the opposite??
You may be joking about facts/arguments or I may be missing something.... but just this info about proportions (assuming it's correct) is news to me.
Helgirl wrote:I think what they are trying to say is that just because you are short it doesn't mean that you don't have longer legs than a man who is the same height as you. What the WSD design is trying to cater for is that most women have a different leg:torso length ratio than men, women's legs are longer & torso shorter. Men have a longer torso & shorter legs, so just because you are short doesn't mean that you don't conform to those proportions.
squeazasis wrote:Yes, I think at times I tend to assume that what's obvious logic to me (and presumably to you too, on the topic of proportions) must be obvious to everyone, so I didn't spell it out.
Having always thought that women had proportionally LONGER trunks compared to men, rather than the other way around, learning that women-specific road bikes have shorter top bars I thought that seemed odd..... and then when the guy from Ivanhoe cycles said about the proportions I assumed that he must be mistaken, hence my comment in my original post! The only thing that I wasn't sure about with the posts in this thread was what PH said about facts getting in the way of a good argument.... I guessed he MIGHT have simply been having a dig about me being wrong (and he's confirmed that that was the case) but thought there might be otheer possible meanings.
Shortening the top tube decreases the reach between the saddle and the handlebars - the most common problem for female cyclists due to our shorter torsos. Just shortening the top tube, though, can lead to other problems - less stable handling and increased toe overlap - unless other modifications are made.
PiledHigher wrote:squeazasis wrote:Yes, I think at times I tend to assume that what's obvious logic to me (and presumably to you too, on the topic of proportions) must be obvious to everyone, so I didn't spell it out.
And yet you have repeated to yourself and the forum your incorrect theory again, better to repeat the correct answer again and again so that is what you remember....
http://www.teamestrogen.com/content/wsdBikesShortening the top tube decreases the reach between the saddle and the handlebars - the most common problem for female cyclists due to our shorter torsos. Just shortening the top tube, though, can lead to other problems - less stable handling and increased toe overlap - unless other modifications are made.
Canuck wrote:My women's Giant small is at least 4 (5?) yrs old now, and while it does feel pretty good, I think it's more because the TT / reach are better for me than on my 'male' Trek, which is a 56. But the Trek feels much better in every other aspect. I'm 173cm, but very short torso, very long legs. One is too small in some ways, the other too big in some ways.
I think looking specifically for the specs you're after is important, as when I bought, the 'equivalent' male version of mine had higher specced componentsDon't rule out non-wsd in the search.
Users browsing this forum: No registered users and 3 guests
